Feature Request: Set “Open in Right Pane” as Default View Mode
Hi Coda team,
I really enjoy using Coda and appreciate how flexible and powerful it is. One feature I really miss is the ability to have pages or rows open in the “right-hand side pane” by default.
This used to be the behavior before, but now it seems to have been removed or changed. Having to manually switch to “Right” every time slows things down.
Please consider bringing this option back or allowing us to set it as the default. It would make a big difference in usability!
Thanks so much,
Dimi
