Hi all,
I can’t quite figure out the correct formula and would appreciate some help.
I’m trying summarize the total of a column called “revenue” if the “check in” dates (another column) are equal to May 2024.
This data lives in another table called “2024 Reservations”.
Thanks in advance!
