I have tried every permutation I can imagine to figure out how to set up a filter on a text field in my project.
Consider this example, where Journal is a Text field:
Why is the result of this filter blank?
I could not get “contains” to work either.
However, inspired from here: try to use this formula in the filter:
RegexMatch([Low Back Pain Bibliography],“Cartilage”)`
The link above also describes how to get rid of the case sensitivity if you want!
I figured this out when having a slightly different problem myself:
“contains” is treating each cell as a single entry. contains("pig dog", "dog") returns a false, but contains("pig dog", "pig dog") returns true.
so if you filter for the whole cell (“Osteoarthritis Cartilate. 2018. […]”) it would work.
Huge thanks - the RegexMatch suggestion works great.
In fact, I was able to extend the idea further and create a Filter Table which lets me enter search criteria on the fly for any/all of the fields:
Perfect, glad it worked!
However, don’t forget the case-sensitivity! If you want to get rid of that, check out the link I pasted earlier
Thanks - I do not see the link for case sensitivity but this works well - is this what you had in mind or is there another solution to get rid of case sensitivity?
thats exactly what @Gregg_Stebben used here. I guess thats be best solution
