I have a table with a list of equipment and information for each piece. I have a second table with a current list of equipment that was done by an outside vendor so the information is not exactly the same. I am looking for a formula which will check serial numbers in table a against the serial numbers in table b and if they do not show up, make the cell red. I have looked and cannot find a way to do this so I thought I would ask here. Thanks for any help you can provide.
Hey there!
Would this thread help out?
If not, feel free to share the document or a little more context and a ton of people in the community would be willing to help out
I managed to get it to work with this
If(thisRow.[Serial #].Contains([Master Equipment List 2.0].[Serial Number]),“YES” ,’’ )
And then used conditional formatting to turn the cell red.
Thanks for the reply!
