We’re seeing errors loading pages, plus looks like the tracker has it too: https://status.coda.io/
Any guidance on when the docs will be back?
-A
-A
Same problem here. Any updates??
Hi everyone. Thank you for reporting. We’re aware of the current Coda outage and truly appreciate everyone’s patience as we look into it. Our team is actively investigating the root cause and working to implement a fix as quickly as possible.
I don’t have a timeline to share just yet, but please know this is a top priority. We’ll continue to share updates as we learn more on our status page: https://status.coda.io/
Thank you for bearing with us ![]()
Following up, the team has identified a fix and begun implementing it across systems. You should now be able to access your docs again. Thank you again for your patience.
yes.
all docs working again.
thanks
