If you ever used the FormatDateTime() hidden formula you faced a annoying thing: which number to pass on the parameters to get the desired result?
Well, to help on this I’ve created this simple quick reference, so you can easily have a glance on all the options available and pick the right one for you.
Just head over this doc: Format DateTime Reference
