A kind member on here kindly helped me getting a formula together to find a date that sits between a start and end date and show a certain columns content based on that.
The formula works fantastic but it keeps giving me an error “Cannot convert value to a specified format”.
It is bit hard to figure out what is going wrong with this without looking at document, if you could share document with support@coda.io it would help us to resolve it quickly.
I’ve emailed it to you and also shared it on here so others can follow incase they run in to the same issue.
Please see attached my document, you’ll notice that if the ‘VAT Rate’ is 20% then the calculations work, if the ‘VAT Rate’ is anything other than that then it gives the error ‘Cannot convert value to specified format’
Much nicer, more readable, and much more performant!
@Juanmata I strongly recommend you move over to @Krunal_Sheth’s formula if you haven’t already, which is better in every way.
For future Codanauts who arrive in this thread, the issue with the original formula (as well as being slower and harder to read) is that two different data types were being returned. Under certain conditions, a percentage was indeed being returned, while under others, a row was being returned. It wasn’t immediately apparent that this was the case because the row’s display column was percentage formatted. As a result, some rows displayed an error, others did not.
A really nice formula and very simple to understand.
Thank you to both for getting me where I needed to be, I’m still at the very start of my project but I’m now on the right track and already using it to track receipts and invoices.
