Gmail Restrictions whereas Pro plan purchased
Hey there,
I have a problem with Gmail pack.
I’ve just purchased the pro plan to have unlimited possibility to send Gmail from Coda button. And now that I want to do it I still have this message :
“Gmail::SendEmail failed - Couldn’t take action in Gmail: too many requests sent”
How can I fix this ? Pretty blocking for us :confused:
Thanks
Can you share a screenshot of your settings for the button and any formulas used? Also, there are Gmail sending limits, but those are usually around 500 to 1,000 per day.
You an also reach out to support and share your doc with us there if you want us to help troubleshoot in the doc. Use the “?” icon at the bottom right of your doc!
