Hello there !
When using the If() formula, Coda helps us write the formula by autocompleting the fields we can use :
Here, I automatically get the value “Jour du mois (1 à 31)” ![]()
But when using Switch() formula, we are lost with ourselves (or at least I am
) and cannot find any easy way to find the fields I want to work with ![]()
Here, impossible to find the value “Jour du mois (1 à 31)” ![]()
Am I missing something ?
Could that same autocomplete option be enabled ?
Thank you for your help ![]()
