How to add a 'click to continue' button?
Hi,
I’m new to Coda and love the flexibility of Coda. Reccently I have been thinking of adding a button that encourages my reader to click a button to reveal the reamaining contents, or a functionality that the remaining contents be revealed only if they have completed a choice, just like the way Brilliant.org or Mathigon do with their courses.
So, is there a method I can do this? Thanks a lot!
Hi, the general logic I would suggest is to make that button check/uncheck a checkbox when it’s pressed, like
SetControlValue(checkbox1, if(checkbox1, false(), true()))
Then, refer to this checkbox in formulas that display the content only when it’s checked, like
if(checkbox1, <content>, "")
Thank you! I will give a it try and see if it solves my problem.
