I would love to have charts which aggregate values per time unit. Currently, I am not aware of a way to have a chart aggregate/sum values per time unit (week/month/year). Is there an easy way to do this?
Thanks, y’all!
What I do for this is:
- Create separate tables with the aggregates I need.
- Create a button that populates the table, either by clearing the entire table and recreating it, or adding new entries as needed for the desired output metadata.
- Create an automation to click the button daily, weekly, etc as needed.
Then you can create report views of this generated data as desired.
Dear @Niklas_Benjamin_Muegge,
With respect for the time of the Maker and yours, by getting the closed result to your expectations, I suggest you provide a sample doc, screenshots with what you have exactly in mind.
Another way is to use a Coda template as start point and amend it in the way you want to see it. Pls. see this one: Event Data · Visualize your data with charts for inspiration.
This support article might be useful too.
@Ed_Liveikis Thanks for your ideas. I was thinking about doing something along those lines too but I would love to see a simple and/or coda-native functionality for this, since this seems like something pretty basic/useful to many non-tech people. @Eric_Koleda are y’all already building something like this?
I understand where you are coming from @Niklas_Benjamin_Muegge but Coda is arguably not simple, and tables, buttons, formulas and automations are the bread-and-butter of Coda.
If you want to take advantage of other existing features, you could try something like this:
- Add a new column to your table, Month.
- Make it display the month of the row, there are different ways to do this, e.g.:
- make it a Date column that shadows the date value of your row in a formula, e.g.
thisRow.Date, and then set the display settings of the column to show year and month e.g. Jan 2022. - make it a text column and do
Concatenate(thisRow.Date.Year(), "-", thisRow.Date.Month()
- Group this new Month column along the left.
- Now you can choose other Rows you want to aggregate and Summarize them as needed:
And then you will have aggregates show up under each group. This may or may not meet your needs but a separate table is a more flexible and powerful option.
