How to format a formula value added to the Canvas as currency eg. $0,000
- Type =
- Add 1000 as formula value
- Displays the value ok
How to format it as $1,000?
Hi @David.Greenwood,
Try with Format("$ {1}",1000)
Thanks @Federico_Stefanato
Is there a way to add the ,000 commas eg $1,000 or $100,000 ?
sure: please have a look at this post by @Paul_Danyliuk:
Be aware that FormatNumber() is an experimental formula.
I get FormatNumber() works but how to combine that with $ Template?
This does not work
FormatNumber(Format(“${1}”,1000),true)
just returns 1,000
Format("$ {1}",FormatNumber(1000, true)) ![]()
That’s it! Thanks
If you need currency there, look into FormatCurrency() instead. The currency code would be "USD" then.
That’s another hidden formula fyi.
Thanks @Paul_Danyliuk
Be good to get these unhidden! Obviously that’s why I found nothing in help
Didn’t remember FormatCurrency()
I have to review the list of hidden formulas ![]()
@All Warning:
Not suggested for production use unless you’re aware of it
Coda now supports formatting for Number, Date and People results, so no more need for FormatCurrency() here!
