Hello Friends,
Is that possible to get multiple columns from the filter formular ?
I am trying to do the follows:
I have a feature list table per project
And I want to filter and display Feature List for each project
ie:
Project | Feature List
foo a:1
b: 2
c: 3
bar alpha:100
The best I can eke out currently is using filters and bullet list, but seems only the feature name is displayed, I couldn’t figure out how to lookup and reference to other columns other than the display column. It is like this
foo a
b
c
bar alpha
The sample doc is here:
Is that possible at all ?
Cheers,
Marvin
