How to modify only visible/filtered rows
Hi,
I would like to press a button on the canvas to modify all the visible/filtered rows in a table only (i.e. set a checkbox to true).
I can’t see a way to do this - can it be done?
Hi @Jeremy_G,
just select the view of the table you want.
It should just modify the rows in the view instead of the entire table then.
Sincerely
Jannis
