I need to circumvent the standard (and often useful) behavior of NOT filtering out the freshly changed row (it gets marked yellow and disappears only after the user focuses on something else). Because for some workflows we need the opposite, and have them hidden right away.
I have multiple use cases where someone grinds on processing rows (e.g. grading assignments). In such cases the usual filtering behavior is rather a bother. We want to click some “approved” button or checkbox, the status of the row changes to be filtered out, and we want it to disappear instantly and look at the next one in its place.
I get that this is not for every scenario, so it should be an option (possibly even accessible for the users, through a toggle in filter bar, or preferably ALSO in some more geral formulaic way, and of course in the right side filter setting panel).
It would be a great help for many colleagues of mine, saving us the necessity of always (think hundreds of time, several people) clicking somewhere else to get the wannabe-hidden row out of focus.
Ah, also/or - if the behavior could be achieved by using the Activate function (but WITHOUT opening up a whole row modal), that would also be an appreciated workaround. Way less accessible though, perhaps a standard way (as described above) should be preferred by many users. Many thanks!
