How to return selected row value and display them
Hi Guys,
I am quite new with Coda.
is there any function on Coda to return the specific value on the row. For example, I select row 1 and then it return the value which at row number 1.
If I choose Row 1 then it return the value.
Need help!
Thank you.
Do you mean access a specific row from outside the table, in a formula?
You can use the formula - [Your Table].Nth(theRowNumberYouWant)
For example (this is an embedded Coda doc - you can right-click on values to see formulas):
Let me know if I’m not understanding your need correctly though.
Great!!. Thanks you very much =)
