I thought I would share a trick that I figured out recently. How to reverse a string value.
Here is the formula that I am using.
TRIM(CONCATENATE(Unique(SEQUENCE(Length(original),1)).FormulaMap(Middle(original,CurrentValue,1))))
I have a table that I enter the original string value into, and then in the resulting column, I put the formula in. It took a bit of work, but it works 100% of the time.
Let me know what you think.
