The image I inserted into coda document seems to rotate the wrong way (also different from the original file). It doesn’t seem to be any option to rotate it, only to resize it.
I cant rotate images at all? Just rotate it in photoshop or gimp and then add it to coda would be my work around?
Hi, thanks for letting us know. We’ve looked into this, but unfortunately (simple as it may seem), there aren’t any ‘quick fixes’, so we’ve added this to our future backlog.
For now the best bet is to rotate in other tools before inserting to Coda.
Best,
Nathan
Thank you.
I did rotate it using other tools before inserting it… for some reason its orientation stay the same way as before I rotate.
