I am trying to make this work
I want the button to add another number to the thing and I want the second button to remove a thing. Hope that makes sense.
You’ll need to update the sharing settings to public for that doc, but if I understand you correctly here’s how you’d do it:
Forgive my ignorance - but I am a newbie. I did update the preference so that anyone can edit. Thanks for that. However I can not get it to work. If I just type it in it put it in quotes. If i hit the = it brings up formulas but not the one you so eloquently wrote. I get thisRow but I don’t see thisRow.Number.
Ah ok - let me show you. You were on the right track with equals sign.
Edit: I’ve updated your doc as well for the increment button - give it a try for the decrement button
Nick_HE I think I figured it out. I was failing to add a “.” so it was not finding the formula. I got the decrease button working. It is very satisfying!
Thank you!
