Severity: Low
Hi!
Just noticed that, in the help pages, when multiple headings share a name, the outline gets confused and shows multiple headings as your “current position” at the same time.
Also, clicking on any of the headings that share a name in the outline takes you to the first one with that name.
This is the page where I noticed the problem: Schema design principles | Coda Help Center
And here’s a gif of the bug:
