Is it possible in Coda to “merge” the items of two lists? In the below example, I want to merge the blue column with the yellow column to get the (hard coded) result in the green column. Is this possible in Coda? (I’ve tried FormulaMap(CurrentValue) every way I can think to try it, but unable to get result in green column.)
Hello @Ander,
Looks like you can do this with a Sequence, FormulaMap, and Slice!
[Desired Result] is:
=Sequence(1,Count(fruits),1).FormulaMap(Concatenate(fruits.Slice(CurrentValue,CurrentValue),": ",[notes.split()].Slice(CurrentValue,CurrentValue))).BulletedList()
edit: even easier with Nth instead!
=Sequence(1,Count(fruits),1).FormulaMap(Concatenate(fruits.nth(CurrentValue),": ",[notes.split()].nth(CurrentValue))).BulletedList()
Which produces the below, hope this helps!
Thanks, Bobby
nth wasn’t working for me, but your passing in of CurrentValue solves that problem.
I also couldn’t figure out how to generate that for loop, but your use of Sequence solves that problem (if I’m interpreting your formula correctly).
Thanks for your help, @Bobby_Ritter !
