I have a long text field, and I’m writing up a storm, typing lots of text, automatically hitting “return” at end of paragraphs.
Each time I do, it tabs me into the next field. Oops – I don’t want to do that!
Is there a way to use a regular return or enter instead of “shift enter” when typing multiple paragraphs into a text field?
Is there a format option for text fields that will do this?
– Maria
Right now unfortunately not, though there are relevant suggestions raised:
I have a lot of documents where some sort of descriptive text is written to one column. I can make that column be Text-typed, which allows me to write multiple lines of text by using Shift-enter. However, this is tiresome and error-prone to remember to write each new line with shift-enter.
Please support making a large text area, or multiline text box, in detail layouts. Pressing enter on those fields should not cause the field to be accepted, but instead should just add a new line automaticall…
It could be a new column type in itself, or just a formatting option of the existing Text column. But the idea would be to have multiline text box with as many options in a toolbar (like the one you have on top a created Section). This is particularly nice for when you expand the row and get the form layout where you could basically include some kind of Wiki in there (not just database fields, like Text which is way too basic for that)
Like for example, Notion takes this one step further and pr…
Also, just as an FYI and slightly interesting, but if you need to use bullet points or similar then be aware that Alt+Enter is another option for creating new lines
