Good Morning! What Javascript tutorial would you recommend for those of us makers interested in building packs? I would pay for a tutorial that specifically addressed the Coda packs builder. I look forward to your feedback.
Hey there! I had no coding background whatsoever before building packs, but have since built a couple of successful packs after doing the following:
Bought a year subscription to Codecademy - I think this was useful. I honestly spent a grand total of 4 hours on their courses, but I think it necessary to get the basic syntax, language, and structure of Javascript (if you don’t have that already). Essentially, if you cant distinguish between a
and[]
and when to use","
vs";"
you won’t get too far. - Start tinkering around and buidling simple packs and use the resources Coda has provided! - There are a ton linked when you start making a pack (see screenshot below)
Thank you so much Scott. I appreciate the feedback.
The first party documentation from Coda is quite robust. Combined with a basic knowledge of JS (I recommend javascript.info), you should have enough to get started.
