For those of you who enjoy using keyboard shortcuts, we have updated the keyboard interactions for interacting with multi-select lists.
Up/Down arrows: navigate up and down the list of options
Space: toggle selection of the current item
Tab/Enter: submit your changes and close the dropdown
Let me know if you have any feedback on the keyboard shortcuts!
Wow! Great work! This will be very useful in speeding up my workflow.
Hello! I was using this feature and it works but when the list is longer than the size of the dropdown and you keep going down via de Up/Down arrows the selector goes out of sight and the dropdown doesn’t follow
I tried it in both Firefox and Chrome it’s the same behavior
Thanks for reaching out! I’ll forward the feedback to the team
This bug should be fixed now!
That’s excellent news! Keep up the good work!
