Launched: Personal canvas controls
Sure thing, @Kelsey_Chan! Will reach out to support and will update this thread if the information received might be useful for others.
Thanks,
Nina
Does using personal rather than collaborative controls affect either the speed of loading the document or calculation times?
For example, does it prevent some of the caching / snapshotting that might otherwise speed things up? I ask because we are using personal controls to “disable” certain slow calculations in a document with a large number of rows. I wanted to make sure this wasn’t counter-productive.
Snapshots use the default value set for the personal control.
If a user has a personal value set for a personal control, we load that personal value each time the user loads the document. Depending on how your doc is set up, loading the personal value may trigger downstream calculations to recalculate.
