Lookup for date columns produces an error
If I have a table with a column formatted as date and use the following formula:
[Table 1].Lookup(Date, thisRow.RowId()) I get an error: “Cannot convert value to the specified format”. However if the column is formatted as a number then I get the expected behaviour.
Just to point out that the columns are formatted correctly to accept the date. Here is what I get. The error is in Column 5. Column 2 has the same formula and behaves properly:
2019-01-05_17-12-39
Anyone encountered this before?
@Cvet
This is my understanding:
[Column 1] = number data type
[Column 2] = number data type
[Column 1] & [Column 2] are matching data types
[Date] = date data type
[Column 5] = data data type
[Date] & [Column 5] are also matching data types
However, RowID() returns a number data type, which does not match the values in the [Date] column you are searching, which is a date data type.
When you place your cursor on a function in a formula, the info modal shows you what data type it returns. (ignore everything in the image below except the formula info modal)
rowid_2019-01-05_1929
@Ander
Thank you very much. This makes sense now. It was my confusion about what the lookup function actually did. What I was trying to do was to reference the value in the column not go searching for it. The error message totally made sense.
The proper way that I should have done it was with something like this:
thisTable.Date.Nth(RowId(thisRow))
