Matching Two Columns
Any ideas on how I might accomplish the screenshot? Having trouble understanding the best way to architect like
if A matches X and Z
and B only matches X
Then go with A and discard B.
Could you give a bit more explanation? Your post and your image seems to conflict each other’s information, so im not exactly sure what you would want.
Thanks @yscias - apologies on the typo. Use case is to get an understanding of tool that have overlapping capabilities.
If Tool A has the Capability of X and Y. And Tool B has the Capability of Y, then I’d like to return Tool B so that we can consider removing since its capabilities are already covered by A.
