I want to enquire Enterprise Plan but unable to do so.
It’s quite a mismatch between the pricing and enterprise plan though. Because lots of small businesses in South East Asia are still using Microsoft and most of them are using basic or standard. However, in Coda, you must sign up for Enterprise to enjoy Microsoft integration.
May I suggest that you might consider changing the Microsoft Packs to Coda Teams pricing ?
Hi @Hendrik_Zhao! Thanks for sharing that feedback & reaching out about the issue, I’ll check with our team on why that might not be working. While I don’t have any updates on the Microsoft-related Packs for now, I wanted to highlight that the Coda integration for Microsoft Teams is available to all users on any tier - you can find it on the Teams app store. It allows you to bring Coda docs into your Teams chats and channels in new tabs. Feel free to reach out to Coda support with any questions on getting it set up if you’re interested.
Yes we are aware. Actually one of my clients is using Airtable and MS Teams integration is available in non-enterprise plan. Now I need to convince them to subscribe to additional 30/month per doc maker just to get MS Teams. It’s quite unfortunate that Teams pack only avaliable in the Enterprise plan instead of Coda Team Plan.
