I’m trying to add the row’s URL link into a cell on that specific row for each row in the table, but none of the formulas I’ve tried are working. Is this doable? What am I missing?
Hi Bobbie,
Welcome to the community!
ObjectLink(thisRow) should do the trick for you, giving the actual URL. In addition, you can optionally give the link a user-friendly display name.
Regards
Piet
That did the trick, thank you!
