I am trying to get URL browse link for a row I want to create. I am able to get the URL , but when I copy the link URL into the column, it turned out to be the “Name” (first display column) of the row instead of showing URL
Then when i tried to convert to Barcode> it only generates barcode for NAME not for URL browselink.
To display the link to a row in one of its columns, you need to copy the link of one of those rows containing the names of doc, page and table, and replace the row ID with the ID of the current row. The resulting formula should look like this:
@M_Schneider Thanks for your help. however it is not working
when I turn them into the link, it will turn to a name with hyperlink.
All i want is a plain text of URL addres, is that possible?
@M_Schneider thank for you suggestion. I did get the text out but when I want to create QR code with Barcode pack. It turn to link again.
I currently find a way out using intergromat to create barcode and upload to dropbox and send it back to messaging application. Then I save it and put it in the table manually.
