The cross-doc sync doesnt properly process newlines.
Original / Cross-doc
Ive tried all variations of Text / Canvas, Enter / Enter-Shift / Enter-Ctrl, and different formatting. Nothing works.
Hey @Anne_SVET , thanks for reaching out and sorry to hear that you’re running into this issue. To clarify, is the column that you’ve provided a screenshot of from your original doc a canvas column or a text column?
I dont know which one is on the screenshot, Ive tried both in both docs
