Notification system in coda
Hi all,
Am using coda more on mobile app.
A need a similar notification system on mobile similar to what notion has.
For example in a column I want to have date and hour and when I have this type of data, I want a notification on mobile at that hour in that day.
Is this possible? With a similar system I could abandon definitely notion
Thank you
:waving_hand: @Viorel_Postica
yes - in general this can be achieved!
if your notifications fall on the hour i.e. 8am, 9am etc - you can use “time-based” automations. Please note, depending on how busy coda servers are at the time, it may take up to 2-5 mins to get your time set notification i.e 9:02am.
but if your notifications fall in between the hours, then would recommend either “Webhook invoked” automations OR a pack Scheduler Pack, extend Coda with Scheduler - Coda.
For the mobile part - need to turn this on in the app. here’s how you do it:
Just to set expectations and not sure how notion does it (if its native / intuitive or not), but in coda - setting notifications and reminders takes a bit more manual work/know-how. Have a search for “reminders” or “notifications” on this forum to get an idea on how best to set it up for you :slight_smile:
hope this helps!
cheers!
Mel
