I’m trying to get a one-way sync working. I’ve tried the code in both Getting Started Guide: Coda API and Al’s bog post. I’ve double checked my API key and doc IDs, but I keep getting a 404 error:
Request failed for https://coda.io returned code 404. Truncated server response: {“statusCode”:404,“statusMessage”:“Not Found”,“message”:“Could not find a table with the specified ID or name.”} (use muteHttpExceptions option to examine full response) (line 240, file “Coda”, project “Coda API”)
I tried to drill down and make sure I’m using the right doc IDs, so I ran the following function:
function printDocs() {
var docs = CodaAPI.listDocs().items;
Logger.log('Third doc is ' + docs[2].id);
That function gave me the ID of the doc I want to use as my source doc. Let’s call it ab1cdeFg2h. I tried to print the tables of the Source Doc with the following:
function printDocTables() {
var tables = CodaAPI.listTables(ab1cdeFg2h);
Logger.log('Doc tables are: %s', prettyPrint(tables));
I got another error: ReferenceError: “ab1cdeFg2h” is not defined. (line 4, file “Get Tables”)
Anyone know what I’m doing wrong? Thanks!
