Opening messages directly in Gmail
Hi all,
I was looking for a way to be able to open any emails that were synced to a table in my doc. I came up with the following workaround:
  1. Create a button with the “Open hyperlink” action
  2. For the URL, use this formula:
CONCATENATE("https://mail.google.com/mail/u/0/#inbox/",thisRow.Email.Id)
Hope that helps.
Regards,
Shaheed
Interesting! Thanks @Shaheed_Fazal. I’m trying to figure out a way to have someone accept or decline a Google Calendar invite, do you think this would work doing this?
Perhaps not directly but if in the similar way to the GMail task I posted, you find out what the event ID is you could navigate to the page directly:
https://calendar.google.com/calendar/r/eventedit/LONGID
I have not tried this but let me know if it works.
