Please consider adding the ability to disable or hide next/previous navigation in detail view.
One not-so-elegant solution in the interim is to filter the “table” (details view) to only display the row you want the user to see.
If you assign each row to a user, the filter could be thisrow.user=user().
This will still show the next/previous buttons, but they’ll be unclickable, and the label will show 1/1
