We use these two applications heavily for managing projects and they will be really handy if connected to Coda.
Hi Ross,
Thanks for the input - feedback like this will drive which packs we go build first. These are high on our list too.
It’s worth mentioning that for service we don’t yet have a pack for, you can often still use our Zapier integration connect. For instance, you can connect Jira to Coda today: https://zapier.com/apps/coda/integrations/jira
Alden
