I am new to Coda but not similar products. Currently I am trying to move our budget calculation from Excel/Google Sheets to Coda.
The issue is that I have two tables and I want to reference a value in table1 in table2 for calculation and then the outcome from table2 in table3 for further calculations.
In a nutshell, let’s say I have table1 with the below data:
Person1 = $20/hr
Person2 = $30/hr
Person3 = $50/hr
The second table I set up has a relation on the name:
Person1 = 5 hours
Person2 = 10 hours
Person3 = 1 hour
In a column in the second table I am trying to use this formula:
I tried referencing the table and the row directly
[Hourly Freelance Expenses].[Hourly rate]
But that just gives me all the values in the Hourly Rate column rather than the specific row’s value. I tried using thisRow with it but it doesn’t seem to work.
Any ideas how I get the value of a specific row in Hourly Rate column so I can multiply it with the number of hours to get the total?
Thanks in advance.
PS: I did search around here and found a few similar things but every time I try the solution the function builder shows that the part of the function doesn’t exist in this context.
First off thank you very much for making this example. I think I got lost in what you did, sorry, I am new to this.
But I can’t access the formulas when I press on “Open in Coda”. And the small view in post gets overshadowed by the message “Not saving, just playing”.
I thought I’d share what I have so you can see what I am trying to do:
All I am trying to do is to multiply Hourly Rate from “Hourly Freelance Expenses” by July Hours and the result would appear in Total in the “Table” table.
As for why I am duplicating the name column, I read somewhere that you need to have a relationship between two tables to be able to use their values in calculations.
I forgot to say… welcome to Coda. Sorry if I got you scared, do not be as you will get to know very fast
You can simply copy the doc (top right button).
Now about your goal, I tend to avoid having exact copies of my data if a specific need doesn’t exist for it.
I your case I don’t see why you would need to have two tables that have the same display value .
Please check your doc and the formula in the Total column. Since you already have a relation Nameyou can use the dot annotation to build a formula such as thisRow.Name.[Hourly rate].Sum() * thisRow.[July Hours] Please ignore the thisRow as it isn’t needed.
IMHO, your use case needs a different doc architecture as I understand that you try to bring a few linked sheets/workbooks into coda and have data segmented by user, pay rate, date (months, year etc).
If that is the case you can reach me out and we can have a look over Zoom and guide you so that your build is scalable, all for free.
Thank you very much @anon1959570 . Your new formula fixed the issue immediately. What I am gleaning is, if I have a relationship between the two tables, I can reference the relationship (in this case Name) and use the . operator to access the other table’s properties. Although for the table I am in, I can just go after the property right away.
I appreciate the offer, really thank you. I will probably take you up on that at one point, the goal of this exercise is to get to know Coda more and understand how its language works. I used to be a developer and also used Notion so trying to wrap my head around how Coda works is taking a bit of time. It is amazing though, nonetheless.
