Hello!
I’m wanting to create a custom connector in power automate. I tried using Swagger which MS supports, but they don’t support “allOf” so that option didn’t work.
Before I go about trying to connect them the manual way, I’m wondering if anyone else has connected the two, or if you’ve had any success or tips.
Sammy
Using webhooks I’ve been able to automate a lot between coda and power automate!
If you don’t mind sharing, what’s your use case? I might be able to help!
I’d also like to integrate with Power Automate. I’m thinking of building a Custom Connector in Power Platform but time is limited!
I’d like to be able to sync tables with Outlook Tasks and Calendars. It would also be good to be able to use Coda table in a Power App and even Sync to SharePoint and Dataverse.
However, for speed, I’ll look at Make.com in the interim.
Hi Micah,
There are a few different things I’d like to do. Can I ask what you have been able to do?
