Problem with Button() and Concatenate
Hi all !
I’m trying to create dynamically a button, and there is always a bottom padding around them, which unalign text and button.
If someone is able to help my, thanks a lot :smiley:
Hi @Tommy_Khalifa,
please share your doc so we can take a deeper Look into your problem.
Sincerely
Jannis
Sure : https://coda.io/d/_dcAqoLt90hT/Test_suPKK
Your comment gave me a hint ! The bug is only visible on firefox. On chrome, or on my android app, it’s working well !
Okay, i suggest you to use Chrome then.
Sincerely
Jannis
