Hello,
there is a problem with using Gmail:
in the corresponding section is a table with date columns. If I send this section via gmail, the date format in the mail is the US standard format. The format set in the table is ignored. The error is well known, until when will the problem be solved?
Another wish was expressed some time ago: the date / time allow the German / European format.
In any case, coda is very good. I hope you keep it up!
Greetings from Cologne / Germany
