I am new in Coda.io I have trying the gmail:message() function to receive the email data, but i can’t obtain any result.
I don’t know how to write de account, I tried with no success some options, with anf without quotes
gmail::messages(xxxx@gmail.com)
has anybody an example?
Thanks
Dear @Luis_Garcia_Bonifaz,
Please have a look at: https://help.coda.io/connect-your-doc/packs/buttons-and-packs
I am sure this will solve your issue
Success,
//JP
I have read the link, but i haven’t found the solution.
My function and the error are this
Dear Luis,
The formula should be in the Automations section, as in the screenshot below
@Al_Chen_Coda, would you like to give a helping hand.
Kind regards,
//JP
I have saw the Automations section and i have resolved the problem with Gmail::Threads()
Thanks
