Hello! My first question to the community! How do I create a formula in a progress bar column that divides the number of checked boxes vs unchecked boxes from a list in the cell, in the same row, in a text column in the same table so that the output (quotient) is the incremental value for the concordant progress bar in the same row; to show progress?
You must split your canvas column with Split(Linebreak)
Then use Paul’s Code for both checked and unchecked tasks
Create columns with .Count() to count the both columns mentionned before
Create the total
And finally in your progress bar, you can for example set max to 1, and make a formula with CheckTasksCount/TotalTasksCount to have the %, like in my own document
