For a project management doc, I have a template table with recurrent types of projects and corresponding phases, tasks, subtasks and subtasks dependencies.
For creating a new project, I have a button in a view of the “DB Projects” that adds the template tasks to the new project:
RunActions(
[TEMPLATE Subtasks by type of projet].Filter([Type of project]=thisRow.[Type of projet]).ForEach(
RunActions(
AddRow(
[All subtasks],
[All subtasks].Projet ,
thisRow.[Project name],
[All subtasks].[Type de projet] ,
thisRow.[Type of projet],
[All subtasks].Phase ,
CurrentValue.Phase,
[All subtasks].Task ,
CurrentValue.Task,
[All subtasks].Subtask ,
CurrentValue.Subtask,
[All subtasks].Notes ,
CurrentValue.Notes,
[All subtasks].[Blocked by…] ,
CurrentValue.[HELPER Blocked by To text]
ModifyRows(thisRow, thisRow.[Subtasks from the template added], True() ))
All these new subtasks are created in the table “All subtasks”.
The problem is when it passes on the template values of the dependencies - relation column “Blocked by…” in “All subtasks”, with the filter:
CurrentValue.Projet=thisRow.Projet and ID!=thisRow.ID
The first time I create a new project of type “Local”, for example, it works (the column “Blocked by…” gets the values from the template and they are a relation value.
If I create a second “Local” type of project (or a third…), it doesn’t work any more… the values are there, but it’s just text, it doesn’t select the value from the relation.
Why is it doing this?
An example doc: https://coda.io/d/_d-f9fqc21bZ/New-project_suntt
Thanks!!
