Hi all
It seems the Selection List controller does not carry over the formatting of the referred table. Here’s a screenshot:
This is where I store all the choices (where I have applied formating to the rows)
and this controller is takig data from the table
And here’s how the selection list looks:
Did I miss something?
Hi Chen,
Formatting will not follow a formula.
Changing the control you are using from a /Multiple Select based on a formula to a /Lookup directly pointing to a table will solve this.
Example:
It is still possible to allow multiple selections on a lookup drop down.
I hope this helps.
Dale
Awesome, That’s a simple fix, thanks Dale!
system
Closed
4
