I open a doc to share it and this tool tip comes up. I am on the free plan. I created another folder and as My docs had no settings. I can’t figure out what is preventing me from sharing .Thanks
Dear @Hamish_Maclean,
I hope you have found a solution for your question.
I it’s still pending did you check out this?
It looks like that in the folder settings the sharing options need to be amended!
Thanks @Jean_Pierre_Traets, I had to delete the docs and start again (well that is what worked anyway). That enabled sharing options. None of my old docs would let me share …
