Request: add more granular filters to the Shopify pack import, e.g. lineitem SKU, customer/order tags
The current Shopify pack has (reasonable) limits on how many rows of data can be pulled from Shopify into Coda.
However, as there is no ability to filter incoming data by customer tags, line item product SKU or any other meaningful dimension, the integration is unusable for us. Even though we are only interested in manipulating a small number of our Shopify customers and orders, we have to bring in all customers/orders and quickly hit the aforementioned import limits.
Itās a real pity, because this integration could be a game changer for how we use Shopify. And it would allow us to centralize much more of our activity into Coda. Adding more import filter options would unlock this whole pack for us.
In our specific case, we have a small subset of Shopify customers that are B2B clients. They are tagged in Shopify and buy only B2B-specific SKUs, so we have a couple different ways we are able to filter those orders when pulling Shopify reports.
However, because we have to pull all our orders together, the 10,000 row limit means we can only get a few weeks of dataāand most of that data is for non-B2B orders which weāre not interested in for these purposes.
P.S.: I played with a Zapier workaround and we can technically do itābut the way the Shopify pack works in creating nested tables behind-the-scenes is really nice (in particular to make 1 row per order with multiple line items, rather than one row per line item)
Hi, @Harry_Doull .
@Martin_Portevin has developed a Shopify pack.
I really donāt know if it has the features you need.
Maybe he can help you.
Just adding a further note: weāre hitting calculation / memory limits because we have 10,000+ rows of Shopify data, most of which we donāt need.
Unfortunately, the nature of the connection means I cannot delete individual rows once the data is imported. If that were possible, that would also be workable.
Thanks for the mention @Breno_Nunes , and sorry @Harry_Doull for not answering earlier. Iāve been quite busy and away from the Coda community.
Indeed my pack allows to filter orders by customer tag. While not natively supported by Shopify API, the pack sync all orders and only returns the filtered value, so you should be able to get below the 10000 limit. No real difference for the end user as a native filtering function, except that the sync might take longer.
Iāve made some good progress on the pack, 2 way sync almost everywhere, metafields (as individual sync tables or directly as columns on a e.g. a product SyncTable) and metaobjects sync, locations, files, translations etc.
I plan to commercialise the pack later but would you be interested to beta test it ? I wrote lots of tests functions but I still recently caught bugs while manual testing. No real documentation written yet
Hi! Any updates on this?
Have been trying to sync Variants but also have been hitting our limit on rows. The most frustrating part is that it is syncing Unpublished Variants, which can thankfully be filtered with the Products sync but then having both syncs quickly eats up space.
Hello @Sarah_Noah_K-POP_BAZAAR
My pack is more or less finished but I havenāt found the time to contact people to beta test it. As it can impact a lot of things in a store, I want it to be as perfect as can be. Plus there are some advanced features Iām not sure are really needed for most of users and some Shopify quirks I had to build workarounds for.
This is the current list of filters available when syncing variants, a bit overkill but it has really helped me when managing a medium sized shop
Anyway, long story short, would you be interested in beta testing it ?
Neat, how you got the specific tags? As far as I know, the arenāt exposed by Shopify
