Are there any plans to update Shopify Pack to add two-way sync?
Maybe @Eric_Koleda could give us some inside info
Hi Breno,
I’m not sure when we’ll get to this, but we’ve recorded your feature request in our internal tracker. It is one of the tougher packs to work with, even just due to the shear amount of data it can pull in, but we’ve got your request recorded now.
Hi, I joined coda because i saw the shopify pack. i enjoy using coda but can not find any way to sync my store to coda. Is there any information on how to do that. the shopify pack requires an API that i cant seem to get.
Hi @BenLee ,
I’ve developed a Shopify pack for my personal use, with two way sync, metafields support etc. Indeed it’s tough to dev and maintain
It’s not quite ready for primetime, but I wanted to know if it would be ok if I made it public and as a paid pack, given there is already an official Coda one ?
Thanks !
Hello @Arbutus_Tools , you need to create a custom app for your store, install it and create credentials.
I’m on my phone so not sure, but I believe this page has all the info you need : Shopify Help Center | Custom apps
