Dear @Cyrus_Janssen,
I am only trying to support in the community at my best knowledge.
Sharing a dummy doc in the community isn’t that difficult,
Go to your dummy doc, go to share and choose " everybody with a link" as in the screenshot:
Then when you go to embed, you click the button " copy embed" and are able to past your doc in your post
Just take that the doc doesn’t contain sensitive info and preferable only the necessary content to try to help you out
@Mario in reading:
[column name].created() // should do the job and then to sort this column accordingly
EDIT:
thisrow.[tumbs up] // and then you can sort the column accordingly - see sample in post below for your kind reference!
On purpose I ask the post a sample, just to be sure to work towards the expected result of the person asking.
