SUMPRODUCT for more than 2 lists/arrays?
Hi, is it possible to use the SUMPRODUCT() function on more than two lists or arrays?
In sheets/excel SUMPRODUCT() works for 30 arrays but here in coda it’s limited to 2. Do you have any idea how could I achieve the results in coda? Is there a workaround?
In my use case I have a table with 3 columns and in each row I have equally sized list of numbers in each cell (see below). The last column would be the SUMPRODUCT() of the 3 lists in each row. In this example below I used SUMPRODUCT() for the first two columns (since the 3rd one’s value is 1 everywhere) but I’d like to include a third column as well:
Coda-sumproduct
Thanks a lot!
Try this:
Sequence(1,List1.Count()).FormulaMap(Product(List1.Nth(CurrentValue),List2.Nth(CurrentValue),List3.Nth(CurrentValue))).Sum()
Turns out by combining Sequence and FormulaMap you have a classic for loop!
Thank you very much!
Unfortunately I didn’t get a notification when you replied so meanwhile I came up with the exact same solution but your answer could have save me a lot of time and frustration :smiley:
I’m also posting here your Tips&Hacks post about the general idea behind the solution:
It’s a really smart hack that can come handy in a lot of different situations.
Thanks again!
