So I was struggling with a problem where I needed to evaluate multiple lists simultaneously. A classic use case for a loop.
Coda doesn’t have built-in formulas for classic loops such as for or while. The closest thing being FormulaMap. It takes a list as input and runs every item through an expression. Inside the expression, you use CurrentValue to reference the current item being evaluated. As a result, CurrentValue can be of any type (row, date, etc).
But there’s no obvious way to get the key, or the item position inside the list.
Unless…
You make CurrentValue to be exactly the same as its position! You can do that using Sequence to create an auxiliary list.
Sequence(1,finalValue) // =[1,2,3...finalValue]
Then run FormulaMap over this list.
Sequence(1, finalValue).FormulaMap(CurrentValue*2) // =[2,4,6...finalValue*2]
Applying it to my case:
//List1 = [1,2,3]
//List2 = [5,7,1]
Sequence(1, List1.Count()).FormulaMap(List1.Nth(CurrentValue)+List2.Nth(CurrentValue)) // =[6,9,4]
The more general form would be:
Sequence(initialValue, finalValue, step).FormulaMap(expression(CurrentValue))
More or less equivalent to
for (i = initialValue; i <= finalValue; i+=step) {
expression // use i here
Since CurrentValue is a number from the sequence, it serves the purpose of the i.
